Missing mounting bracket bolts for 100 degree panel antenna
  • 2
  • Problem
  • Updated 2 years ago
  • Solved
I was working with a customer on a major wireless deployment when we discovered that there are no bolts included for attaching the articulating mounting bracket to the WS-AO-DE07100N, Outdoor, 2.4-2.5/5.15-5.875GHz, 8-feed, 7dBi, 100 degree panel antenna.
I ended up ordering the required bolts from boltdepot.com, 1-866-337-9888. The Bolt Depot part number for the bolt is 16062 with a description of “Hex bolts, Stainless steel 316, 1⁄4’’-20 x 1/2’’
Hope this helps,
George
Photo of George Smith
George Smith, Employee
  • 110 Points 100 badge 2x thumb
Posted 2 years ago
  • 2
Photo of Drew C.
Drew C., Community Manager
  • 40,218 Points 20k badge 2x thumb
Thanks for sharing this, George.  I'll pass this along to have an article written in GTAC Knowledge.
Direct link to the bolts on their site: https://www.boltdepot.com/Product-Details.aspx?product=16062
You are welcome!!!
Photo of Paulo Francisco
Paulo Francisco, Employee
  • 1,534 Points 1k badge 2x thumb
Our FAI team is currently investigating. They're checking the BOM with manufacuring and validating a unit out of warehouse. We'll confirm their findings.
