MSM B does not synchonize with MSM A
  • Question
  • Updated 8 months ago
  • Answered
Hello,
We have a BD8806 with two MSM-48c slots. but Backup slot B is not syncing with slot A,
I checked Memory usage and only 4% is used!
Omurga_SW02.18 # show slot
Slots    Type                 Configured           State       Ports  Flags
Slot-1   8900-10G24X-c        8900-10G24X-c        Operational   24   M
Slot-2   8900-10G24X-c        8900-10G24X-c        Operational   24   M
Slot-3   10G2Xc               10G2Xc               Operational    2   M
Slot-4   10G2Xc                                    Initializing   2
Slot-5                                             Empty          0
Slot-6   G48Tc(PoE)           G48Tc(PoE)           Operational   48   M
MSM-A    MSM-48c                                   Operational    0
MSM-B    MSM-48c                                   Present        0
Omurga_SW02.17 # show sw
SysName:          Omurga_SW02
SysLocation:      SAMULAS
SysContact:       support@vegaalarm.com,+903224562228
System MAC:       00:04:96:99:55:75
System Type:      BD-8806
SysHealth check:  Enabled (Normal)
Recovery Mode:    All
System Watchdog:  Enabled
Current Time:     Tue Mar  6 16:04:52 2018
Timezone:         [Auto DST Disabled] GMT Offset: 180 minutes, name is not set.
Boot Time:        Tue Jan  2 11:51:13 2018
Boot Count:       14
Next Reboot:      None scheduled
System UpTime:    63 days 4 hours 13 minutes 39 seconds
Slot:             MSM-A *                      MSM-B
Current State:    MASTER                       BACKUP
Image Selected:   primary                      primary
Image Booted:     primary                      primary
Primary ver:      12.5.4.5                     16.2.3.5
                                               patch1-6
Secondary ver:    12.5.4.5                     16.1.3.6
Config Selected:  primary.cfg
Config Booted:    primary.cfg
primary.cfg       Created by ExtremeXOS version 12.5.4.5
                  487068 bytes saved on Tue Mar  6 08:59:51 2018
Your help is highly appriciated!
Yusuf
Photo of Yusuf Kabbara
Yusuf Kabbara
  • 524 Points 500 badge 2x thumb
Posted 8 months ago
Photo of Patrick Voss
Patrick Voss, Alum
  • 11,714 Points 10k badge 2x thumb
Hello Yusuf,
Is it giving you an error? or failing during the synchronization?
Photo of EtherMAN
EtherMAN, Embassador
  • 7,370 Points 5k badge 2x thumb
Image differences ... you can't have one running 12.5 and the backup running 16.2.
You will need to downgrade B or update A.
To downgrade B to A's image you could force a sync.  This should be not effect network and be non-impacting. A will copy it's primary and secondary images over to B and B will reboot and come back up synced.  It would be better to upgrade to current code but you would have to have a system reboot for that due to code differences
Yusuf Kabbara
Hello @EtherMAN,
I cannot find 16.2, could you please help downloading it!?
Thank you
Yusuf
Yusuf Kabbara
And
- What if I did a <run failover>, would I be able to run on B slot and upgrade A slot later?
- Is there any way to sync A from B?
Photo of EtherMAN
you will need a valid support contract to access the downloading of images... You will need to call TAC if you do not have a contract and this is a new card to see what options you may have.
