Netsight licence V7 will work for Extreme Management Center V8?
  • 4
  • Question
  • Updated 1 year ago
  • Answered
If I upgrade to NMS V8, will I need to upgrade V7 license key to v8 as well or it will work out of the box?
Thanks,
Rahman
Photo of Rahman Duran
Rahman Duran
  • 2,012 Points 2k badge 2x thumb
Posted 1 year ago
  • 4
Photo of Mike Thomas
Mike Thomas, Employee - GTAC - NMS
  • 7,650 Points 5k badge 2x thumb
A license generated after 6/1/2017 will work for 8.x.
So it is likely it will have to be  regenerated. However, if it was regenerated after 6/1/2017 - you can use it for version 7 or 8.
(Edited)
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 49,972 Points 20k badge 2x thumb
Thx Mike
Rahman Duran
Our license upgraded from v6 to v7 on 07/jun/2016. So we need to upgrade to V8 again? What is the minimum service contract for software upgrades btw?
Yes you will.
The upgrade is based on the NMS-XXX license. So you are not re-licensing all NMS related products (Analytics flows, appliances, etc), effectively the server itself. You want it to be the same contract coverage as before, or it will regenerate a license with less features.
