No user session on XMC
Good Morning Last week we replaced an Enterasys S4 with a pair of X590s. We no longer display the user session, we do not display anything on the End-System. can you help me. Thank you Giuseppe
Hi, I am trying to play wit factory default script called “Download Configuration”. Thats a simple script to download config from XMC back to switch. Unfortunately script is reporting unknown emc_vars errors. I wonder if anyone used that script wi...
Hi anybody, I have different informations about the running NAC-version. Inside EMC shows me in „Access Control“ 8.4.0.116. But VM manager shows me “nac_appliance_64bit.8.1.0.52-Medium”. Can I install on the running NAC appliance 8.1.0.52 the “nac...
Is there a way to have alarms auto clear if the event causing the alarms clear.
Hi Guys, How to Configure Management IP address of VDX switch to connect to Extreme XMC? And Set up SNMP Configuration Thanks, Sazon
| User | Count |
| 106 | |
| 102 | |
| 44 | |
| 19 | |
| 17 |
