Port bounces up and down once after reboot: X670G2-48x-4q
  • Problem
  • Updated 1 year ago
  • Not a Problem
After reboot of the switch some port are bouncing up and down one time. We don't see any reason for this and it's causing traffic loss for us.
11/16/2016 13:19:22.61 <Info:vlan.msgs.portLinkStateUp> Port 49 link UP at speed 40 Gbps and full-duplex
11/16/2016 13:19:20.21 <Info:vlan.msgs.portLinkStateUp> Port 10 link UP at speed 10 Gbps and full-duplex
11/16/2016 13:19:20.21 <Info:vlan.msgs.portLinkStateUp> Port 9 link UP at speed 10 Gbps and full-duplex
11/16/2016 13:19:20.58 <Info:vlan.msgs.portLinkStateDown> Port 9 link down - Local fault
11/16/2016 13:19:21.49 <Info:vlan.msgs.portLinkStateDown> Port 10 link down - Local fault
11/16/2016 13:19:24.75 <Info:vlan.msgs.portLinkStateUp> Port 10 link UP at speed 10 Gbps and full-duplex
11/16/2016 13:19:24.75 <Info:vlan.msgs.portLinkStateUp> Port 9 link UP at speed 10 Gbps and full-duplex
11/16/2016 13:19:33.11 <Info:vlan.msgs.portLinkStateDown> Port 49 link down - Local fault
11/16/2016 13:19:35.93 <Info:vlan.msgs.portLinkStateUp> Port 49 link UP at speed 40 Gbps and full-duplex
Is this some known behaviour or do anyone have a idea what could cause such behaviour.
If you wonder we are running test activitys within mobile networks and this is part of some testcases.
Photo of Anders Sjökvist
Anders Sjökvist
  • 160 Points 100 badge 2x thumb
Posted 2 years ago
Photo of Naresh
Naresh, Employee
  • 1,296 Points 1k badge 2x thumb
Hi Anders,
  1. What is the device connected to the ports 9 and 10?
  2. How often the ports are flapping?
  3. Are the ports 9 and 10 are part of a Link Aggregation Group?
  4. What is the Exos version running on the switch?
For more information on the fault detection process please use below link to find the article:
https://gtacknowledge.extremenetworks.com/articles/Q_A/what-is-the-difference-between-local-fault-an...
To isolate the issue with layer 1 please check below steps:
  • Please reseat the SFP module and check the status.
  • Please move the problematic links to another port to see whether ports are still flapping or not.
  • Please check for any errors on the port using the command “# show port rx errors” and “# show port tx errors”.
  • Please check the same in other end of the device connected to the ports 9 and 10
(Edited)
Anders Sjökvist
Sorry if was a bit vague in my question. :)
Connected are ericsson telecom equipment under test.
The ports only bounces up and down one time after reboot of the switch.
Port 9-10 is a LACP LAG.
EXOS 16.1.3.6
And we dont know if it's the switch causing the problem, it can just as well be a problem in the other end but as it's only ocures after the reboot of the extreme-switch we started to look there.
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,888 Points 5k badge 2x thumb
Andres,
I guess the switches are not in production, so in case if you can change the configuration and reboot the switch at will then i would suggest to isolate the issue with below steps.
remove the ports 9,10 from all the VLAN's
loop back the ports 9 and 10 using the same cable used in port 9 or port 10.
reboot the switch and see if the ports are flapping.
Try the same on the Telecom equipment.
This could give a fair idea where the issue is.
I would get back if i find any such case is recorded before.
Anders Sjökvist
Thanks for your reply we will continue to trouble-shoot here and if appreciate that you look arount for a simular case.
BR
Anders
Anders,
I checked the database and and could not find a similar issue reported.
Still i would wait for others to comment in case if i missed any similar instances.
Photo of Drew C.
Drew C., Community Manager
  • 38,546 Points 20k badge 2x thumb
Hello Anders,
Have you been able to resolve this problem?
Photo of dong zhenghao
dong zhenghao
  • 60 Points
Hi
I have the same problem again, the bouncing ports are:
1.isc ports connected to peer switch;
2.the ports connected to HP GEN7 Host (EXSI).
(No STP running.)
Is it maybe because the extreme switch port is 10G FULL DUPLEX, and EXSI side is AUTO-Negotiation?
Thanks.
BR
Dong
