Port channel between x440g2 48 p and cisco cat 6500
  • Problem
  • Updated 8 months ago
  • Not a Problem
i have configured port channel on my cisco and extreme switch but when i connect the interfaces the port channel doesnt come up not sure what i am doing wrong here. please see configuration
CISCO CONFIG
interface Port-channel2
 description 7th Floor Copper Trunk Uplinks
 switchport
 switchport trunk encapsulation dot1q
 switchport trunk allowed vlan 1-14,16-20,24-29,31-4094
 switchport mode trunk
 bandwidth 4096000
 no ip address
 logging event link-status
 logging event spanning-tree status
 logging event bundle-status
 logging event trunk-status
 load-interval 30
 snmp ifindex persist
 mls qos trust cos
 spanning-tree portfast trunk
 spanning-tree link-type point-to-point
end
interface range GigabitEthernet2/11 - 12
 description 7th Floor Copper Uplink 1
 switchport
 no ip address
 load-interval 30
 keepalive 30
 mls qos trust cos
 channel-protocol pagp
 channel-group 2 mode desirable
end
EXOS CONFIG
enable sharing 1:2 grouping 1:2,3:48 algorithm address-based L2
sh sharing detail
Load Sharing Monitor
Config    Current Agg     Min    Ld Share  Dist  Ld Share  Agg Link  Link Up
Master    Master  Control Active Algorithm Flags Group     Mbr State Transitions
   1:2    1:2     Static     1    L2        A     1:2       Y     A       5
                                  L2              3:48      -     R       1
Photo of Lutha
Lutha
  • 304 Points 250 badge 2x thumb
Posted 8 months ago
Pagp is a Cisco proprietary protocol it is not support by any other vendor, you need to configure the Cisco with LACP.
Regards
Photo of Brian Austin
Brian Austin, Employee
  • 412 Points 250 badge 2x thumb
Lutha,
 please note if you need to configure the exos side for lacp as well as it looks like it is currently setup as a static lag
the following article should be able to help you achieve this:
https://gtacknowledge.extremenetworks.com/articles/How_To/how-to-configure-sharing-LAG-LACP-in-Summi...
Regards,
Photo of Lutha
Lutha
HI Guys
I have tried below configuration and port channel still doesnt work
 interface Port-channel 3
 switchport
 bandwidth 4096000
 no ip address
 load-interval 30
 mls qos trust cos
end
interface range GigabitEthernet3/7 - 8
 description 7th Floor Copper Uplink 3
 switchport
 no ip address
 load-interval 30
 keepalive 30
 mls qos trust cos
 channel-group 3 mode active
end
 on extreme side
enable sharing 1:2 grouping 1:2,3:48 algorithm address-based L2 lacp
m at my wits end now m not sure where i go wrong
Can a member kindly share their port channel configs between cisco device and extreme.
Thanks
Photo of Brian Anderson
Brian Anderson
  • 722 Points 500 badge 2x thumb
Photo of Lutha
Lutha
I have checked the logs and theres no error like this
LACPDU. Actor: System ID 0x0000, 00-04-96-44-05-d0; Key 0x0efd; Port ID 0x0000, 0x0fea; State 0x0d. Partner: System ID 0x8000, ca-fe-22-42-be-ef; Key 0x0001; Port ID 0x8000, 0x0001; State 0x04. Collector: Max delay 0.
or any error to do with port-channeling
only message i see in logs is the below
12/19/2017 17:58:06.54 <Info:vlan.msgs.portLinkStateDown> Slot-1: Port 3:48 link down
12/19/2017 17:57:10.14 <Info:vlan.dbg.info> Slot-1: Port 1:2 is UP with speed 1000, Add to aggregator 1:2 with speed: 1000
12/19/2017 17:57:10.14 <Info:vlan.msgs.portLinkStateUp> Slot-1: Port 1:2 link UP at speed 1 Gbps and full-duplex
12/19/2017 17:56:47.69 <Info:vlan.dbg.info> Slot-1: Port 3:48 is UP with speed 1000, Add to aggregator 1:2 with speed: (down)
12/19/2017 17:56:47.69 <Info:vlan.msgs.portLinkStateUp> Slot-1: Port 3:48 link UP at speed 1 Gbps and full-duplex
12/19/2017 17:56:37.49 <Info:vlan.dbg.info> Slot-1: Port 3:48 is Down, remove from aggregator 1:2
12/19/2017 17:56:37.49 <Info:vlan.msgs.portLinkStateDown> Slot-1: Port 3:48 link down
12/19/2017 17:41:27.45 <Info:vlan.dbg.info> Slot-1: Port 3:48 is UP with speed 1000, Add to aggregator 1:2 with speed: (down)
12/19/2017 17:41:27.45 <Info:vlan.msgs.portLinkStateUp> Slot-1: Port 3:48 link UP at speed 1 Gbps and full-duplex
A few seconds after plugging the second port the switch starts to slow down in between commands as soon as i disable the port the switch runs normally again
Brian Anderson
Sounds like a loop and the port channel isn't working.  I noticed on port 3 on the cisco you don't have this command: channel-group 3 mode active.  Does that command need to be on that interface?
Photo of Lutha
Lutha
the port-channel does not take the command. the command is applied to the individual ports the will be joining the port channel which is nterface range GigabitEthernet3/7 - 8
Photo of Erik Auerswald
Erik Auerswald, Embassador
  • 12,850 Points 10k badge 2x thumb
You would see log messages about an invalid LACP system ID on the Cisco switch, not the Extreme switch.
Photo of Lutha
Lutha
Is there another method of acheiving  this between cisco and extreme
Since the switches slow down after activating both links there seems to be a significant problem, thus if you try to use a static LAG, you would probably make the situation worse.
Hi Lutha
This is what i have on my switches and the port channel works
on cisco side:
interface Port-channel20
 description SCPDA010200
 switchport
 switchport trunk native vlan 999
 switchport trunk allowed vlan 100,113,201,300,400,501,601,613,1000,1200
 storm-control broadcast include multicast
 storm-control broadcast level 2.00
 spanning-tree guard loop
 ip dhcp snooping trust
end
interface TenGigabitEthernet1/14
 description SCPDAA010200 3:49
 channel-group 20 mode active
end
interface TenGigabitEthernet1/13
 description SCPDAA010200 2:49
end
on Extreme side:
enable sharing 2:49 grouping 2:49,3:49 algorithm address-based L2 lacp
If you are using fiber you should configure the guard loop also by default on MSTP and RSTP the link types are point-to-point.
Hope this helps
Regards
  • 12,854 Points 10k badge 2x thumb
Hi Lutha,
you should verify that the links are connected the way you want. You could enable LLDP on both the Cisco and Extreme switches, enable just one of the links, and then verify LLDP neighbors on both switches, and verify LACP information received on both switches.
Then you disable this port again and enable the other port. There you perform the same checks.
After that you closely examine the the LLDP and LACP information, as well as the logs of both switches, if everything is OK.
Since you seem to be using STP, you should verify STP operation as well.
Your configuration looks OK on first glance, I have not yet experienced problems with LACP between Cisco IOS and EXOS switches. Thus I'd say you need to dig deeper to find the root cause.
Thanks,
Erik
