Simple VoIP configuration
  • Question
  • Updated 6 months ago
  • Answered
I have a client with only 1 vlans - the default vlan and a VoIP called ENAVoice.  All the tagging is done at the phone handset.
create qosprofile "QP5"
configure vlan "ENAVoice" qosprofile QP5
configure dot1p type 5 qosprofile QP5
configure dot1p type 6 qosprofile QP5
configure diffserv examination code-point 46 qosprofile QP5
Is there any more that needs to be done to give VoIP priority?
fyi - the creation of ENAVoice tagged 200 and then enabeling of ELRP are the only things this customer has beyond a default configuration.
Photo of Joshua Beddingfield
Joshua Beddingfield
  • 280 Points 250 badge 2x thumb
Posted 6 months ago
Photo of Eric Burke
Eric Burke
  • 3,500 Points 3k badge 2x thumb
Joshua,
My understanding is that you can't use both Dot1P and DiffServ together. In our standard build, we issue a "disable dot1p examination ports all" following the config diffserv line.  Here's what our template looks like:
create qosprofile qp5
config diffserv examination code-point 34 qp5
config diffserv examination code-point 46 qp5
enable diffserv examination ports all
disable dot1p examination ports all         # if you don't disable dot1p, diffserv won't work
Eric
Joshua Beddingfield
Thanks. I will try that.
Photo of Sushruth Sathyamurthy
Sushruth Sathyamurthy, Employee
  • 998 Points 500 badge 2x thumb
Hi Joshua,
Please check the following article
https://gtacknowledge.extremenetworks.com/articles/How_To/Configuring-QOS-profiles-and-verify-QOS-is...
These two points may be of relevance -
  • If traffic is expected to ingress with a DSCP or dot1p value, examination will need to be enabled on the port
  • If the traffic is not expected to ingress with a DSCP or dot1p value already set, ensure examination is disabled and the value is set via VLAN or port
Photo of Kawawa
Kawawa, GTAC
  • 3,292 Points 3k badge 2x thumb
If the traffic is already being tagged by the phone and phone is tagged in the VLAN, then the following line is redundant and all you need to do is configure and enable examination:
# configure vlan "ENAVoice" qosprofile QP5
Dot1p values are carried in the 802.1Q header, so the phone port MUST be tagged in the ENAVoice VLAN, if not, then those Dot1p values will be stripped and the above command can be used to re-apply the value to the traffic
DSCP values are carried in the IP Header, so port tagging is inconsequential.
A stream can have both a Dot1p and DSCP value set.  On inspection, the Dot1p value will always take precedence.
You can verify your configuration by looking at the following output, if the QP counters are increasing in the correct queue then all is well:
# show ports <port | port-list> qosmonitor
Port Qos Monitor
Port         QP1      QP2      QP3      QP4      QP5      QP6      QP7      QP8
             Pkt      Pkt      Pkt      Pkt      Pkt      Pkt      Pkt      Pkt
            Xmts     Xmts     Xmts     Xmts     Xmts     Xmts     Xmts     Xmts
1              0        0        0        0        0        0        0        0
2              0        0        0        0        0        0        0        0
3            200        0        0        0        0        0        0        0
4              0        0     2398        0        0        0        0        0
5              0      180        0        0        0        0        0        0
6              0        0        0        0        0        0        0        0
7              0        0        0     1533        0        0        0        0
8              0        0        0        0        0        0        0        0
9              0        0        0        0        0        0        0        4
10             0        0        0        0        0        0        0    51504
Kind regards
