Upgrade bootrom on module in BD8810
  • Question
  • Updated 2 years ago
  • Answered
I installed a new module in our BD8810 this morning and it logged "HAL.Card: MSM-A: Slot 4 bootrom is out of date, do 'install firmware' to install"
Can I run install firmware and it will update the bootrom on only this module and not affect anything else since they are all at already? I can then reboot Slot 4 so it comes up on the new bootrom? This is a core switch and I cannot take it down.
Photo of DH
  • 984 Points 500 badge 2x thumb
Posted 2 years ago
Photo of Andrew Imam
Andrew Imam, Employee
  • 1,006 Points 1k badge 2x thumb
Hi DH,
Yes. I believe when you execute the "install firmware" command, it will check if  the BootROM version on any other IO module, MSM, etc.. need updating as well, and will let you know if that is the case. You have the option to select/specify which one(s) you would like to update.  As you know updating the BootROM  on Slot 4 will require a reboot of the module. You can use the "disable slot 4", "enable slot 4" to reboot the I/O module in question.
Please let us know if you have any other questions.
Thank you.
Best regards,
Photo of DH
HI Andrew,
Great, thanks for the reply and verifying what I was thinking.
Photo of DH
When I run the install firmware it says the firmware versions are current but I can see that slot 4 is still at
What if I run install firmware force, will that force it to upgrade?
Photo of Ijaz Chughtai
Ijaz Chughtai, Employee
  • 220 Points 100 badge 2x thumb
'force' option installs the new firmware without a version check. Please see the command details with example output for BD platforms.
if you are still seeing the log message about slot 4 image being out-of-date even after running the 'install firmware' command, then 'force' option can be used.
Photo of Stephen Williams
Stephen Williams, Employee
  • 8,626 Points 5k badge 2x thumb
Did you get it upgraded?
