V2110 kernel messages
  • Problem
  • Updated 5 months ago
  • Solved
Hello, all!
First install of V2110 on Hyper-V.
And can't ping it
Does anybody saw likethat kernel messages?
Thank you!
Photo of Alexandr P
Alexandr P, Embassador
  • 12,670 Points 10k badge 2x thumb
Posted 5 months ago
Photo of Gareth Mitchell
Gareth Mitchell, Extreme Escalation Support Engineer
  • 5,670 Points 5k badge 2x thumb
Hi Alexandr
If you have deployed the v2110 factory image and haven't modified it in any way, then I would say you should open a case with GTAC, if you've changed anything, like CPU, memory, NIC cards, then please redeploy the factory image and see if that helps.
-Gareth
Photo of Alexandr P
Hi, Gareth!
Issue resolved with reinstall controller's image.
Thank you!
