VDX 6740 active standby problem
  • Problem
  • Updated 2 weeks ago
Hello,
I have 6 VDX 6740 switches.
on one of them I have this situation.
sw0# sh ver
Network Operating System Software
Network Operating System Version: 6.0.2
Copyright (c) 1995-2015 Brocade Communications Systems, Inc.
Firmware name:      6.0.2h
Build Time:         22:04:56 Apr 12, 2018
Install Time:       18:15:41 Oct  3, 2018
Kernel:             2.6.34.6
BootProm:           1.0.1
Control Processor:  e500mc with 4096 MB of memory
Slot    Name    Primary/Secondary Versions                         Status
SW/0    NOS     6.0.2h                                             ACTIVE*
                         7.0.2b
so SW/1 is not coming up.
is there a way to force it to get up ?
Also there is a secondary image 7.0.2b   which I would like to wipe.
on my other switches I have
switch-ana-vdx01# sh ver
Install Time:       16:28:19 Sep 27, 2018
Kernel:             2.6.34.6
BootProm:           1.0.1
                6.0.2h
SW/1    NOS     6.0.2h                                             STANDBY
                6.0.2h
thanks
Photo of Riccardo Veraldi
Riccardo Veraldi
  • 282 Points 250 badge 2x thumb
Posted 2 weeks ago
Photo of Jason Howlett
Jason Howlett, Employee
  • 142 Points 100 badge 2x thumb
Ha Sync command should be used here
Photo of Yulia Abitbul
Yulia Abitbul, Employee
  • 472 Points 250 badge 2x thumb
Netinstall will install the firmware like a new switch. This can be useful when a switch is experiencing the following issues and it will take too long to fix manually:
  • One of the GOS partitions (SW/0 or SW/1) is missing
  • Switch cannot fully boot up due to a software issue (ex:Firmware upgrade or downgradewent wrong and now the switch will not boot, switch is in a reboot loop)
  • Corrupted file system or CF (compact flash)
Riccardo Veraldi
the first thing I tried is ha sync and it did not solve the problem.
if I go for Netinstall is there a way to backup the licenses which are now installed and reinstall them back  at the end ?
you can find licence string with the following command:
show logging raslog | i license
Copy and save the license key *B 7F:l:L5jZZ.......#
then you can added it back as in the article:
https://gtacknowledge.extremenetworks.com/articles/Q_A/Licensing-on-VDX/
(Edited)
