VTP Santandards on Switch Extreme
Tavares_Belmont
New Contributor II
Hello Guys!
How can i create and share multiple vlans across many switches connected by trunk link together? It's possible make that like VTP protocol on cisco switches? What feature i can use to accomplish this task?
3 REPLIES 3
Alexandr_P
Valued Contributor
Hi!
MVRP don't work normally with sharing groups with EXOS earlier then 15.7
Tavares_Belmont
New Contributor II
Thanks a lot!! a I gonna try now!
Andrew_Maldonad
Tavares,
You may want to look into Multiple VLAN Registration Protocol (MVRP). Multiple Registration Protocol/Multiple VLAN Registration Protocol is similar to VTP in that it is used for dynamically creating VLANs and/or dynamically adding ports to VLANs.
-Andrew
