Wireless AP authentication failure.
  • Problem
  • Updated 1 year ago
  • Solved
I am seeing this message on both my Identifi Controller V2110, as well as in the Netsight Console. "A Wireless AP has attempted to connect with outdated key information. Wireless AP authentication failure. " This only seems to be occurring on the secondary channel to the backup controller!!! What happens is the secondary channel cannot be established. Netsight Suite is currently running 7.0.6.27 and Identifi is on 10.21.03.0010. The model AP is 3825i. Please advise how I may resolve this issue. Thanks
Photo of Dean Ferraro
Dean Ferraro
  • 832 Points 500 badge 2x thumb
Posted 1 year ago
Photo of Hawkins, Bruce
Hawkins, Bruce, Employee
  • 1,312 Points 1k badge 2x thumb
This typically means that the key pairs that have been exchanged between controllers in your High Availability Pair have become invalid for some reason.
To fix this, we briefly make both controllers "Standalone" (making note of which IPs were used to build HA on each side, which controller is configured as "Primary", and which (if any or both) synchronization options have been configured FIRST) and what the Fast Failover timeout value has been set for ...  for a minute or two ... thereby breaking the pairing ... and then after that brief stint as two separate and standalone controllers ... re-pair them using the settings you had in place previously.
This should fix things for you.
Photo of Bin
Bin, Employee
  • 5,374 Points 5k badge 2x thumb
Hi Dean,
Please take a look the following article.
AP Foreign AP count invalid, outdated key messages for backup controller
https://gtacknowledge.extremenetworks.com/articles/Solution/AP-Foreign-AP-count-invalid-outdated-key...
Best regards
