Wireless clients sporadically getting Limited Connectivity, APs dropping packets
  • 9
  • Problem
  • Updated 2 years ago
  • Solved
  • (Edited)
We have a pair of V2110 wireless controllers and around 400 3825i access points.  Controller firmware is  09.21.06.0002.  AP firmware is 9.21.27.1387X.
About 4 months ago we noticed a problem where the APs would just drop traffic.  A packet capture will show a ping coming into the radio from the client, going out the Eth interface on the AP, the reply coming back into the Eth interface, and never going out of the radio.
A particularly strange detail is that this only happens with certain source/destination traffic.  For instance a client cant ping the gateway of 10.1.20.1/24. but cannot pint the server at 10.1.20.2.  Since we can see the ping making it to the server and the ping reply making it back to the AP, we know it's not a firewall/ACL/routing issue on any other part of the network.  The traffic disappears at the AP.  Clients cannot communicate with anything on the Internet or any of our servers (DNS, DHCP, etc.) during this time.  They can ping gateways in any subnet but that's it; everything else is failed.
More details:
-We've gone through several firmware updates with GTAC.  Nothing has helped.
-The issue can affect any client on any AP in any location at any time.
-The issue is intermittent; it may happen every few minutes or once per month to a particular client in a particular area.  Once failed it may last for seconds or days.
-While it's affecting one client, other clients on the AP may be working fine or may also fail.
-It can happen on either 2.4 or 5.7GHz.
-It can affect any type of client (phone, laptop, tablet) and any OS.
-Restarting the client or AP will sometimes fix the issue, sometimes not.
-It happens with our without using NAC, or any other type of authentication.  It happens on completely open networks as well.
-It happens on both bridged at AP and bridged at controller topologies.
-It's not limited to a particular subnet or VLAN.
-It happens with or without Flexible Client Access enabled.
-It happens on either controller.
-GTAC hasn't made much progress on the issue in 4 months.
Photo of Ron Oley
Ron Oley
  • 350 Points 250 badge 2x thumb
  • Frustrated
Posted 3 years ago
  • 9
Photo of Bill Handler
Bill Handler
  • 1,414 Points 1k badge 2x thumb
9.21.06?  You must have an early release.  The newest I can see is 9.21.05.
Were your controller upgraded from V8 code?
We ran into an issue at a customer site where clients would connect, but would not get a DHCP address.  It seemed to be at random times/locations.  If you walked around one of the sites, you would suddenly get an IP and be online and working.
All went away once we recreated the VNS.  We figured that somehow, over time/updates, the VNS/WLAN got corrupted.  Recreating it with the same filters/roles/COS settings resolved our issue.
We have not had the issue return since.
Thanks,
Bill
Photo of Drew C.
Drew C., Community Manager
  • 40,218 Points 20k badge 2x thumb
9.21.06.006-1 was made available for download on the Extranet moments ago:  https://extranet.extremenetworks.com/downloads/Pages/WirelessControllers.aspx
(Edited)
Photo of Ron Oley
Ron Oley
Correct, we were sent an early release by GTAC.
This issue happens on every VNS (we've created 4 or 5 new ones for testing at this point).
I'm not sure which version of code our controllers started with.  Might there be a log of that somewhere in the software?
(Edited)
Bill Handler
Logs/SW Upgrade I think
Have you tried to spin up a new fresh 2110?
Photo of JP
JP
  • 984 Points 500 badge 2x thumb
Are you using Radio Preference load groups ?
Photo of Ron Oley
Ron Oley
In one area (5 APs) on campus we are, but we haven't had any issues in that location.
Photo of Evan Kuckelheim
Evan Kuckelheim
  • 678 Points 500 badge 2x thumb
Have you had any problems since?
Kinda looking at the same situation.
3825i and a V2110 medium at the same patch level.
(Edited)
Evan Kuckelheim
on 09.21.06.0006 at the moment.
Photo of Doug Hyde
Doug Hyde, Technical Support Manager
  • 20,616 Points 20k badge 2x thumb
Code 9.21.07 should address this issue. The ETA on this code should be the end of this month...
Reference: https://gtacknowledge.extremenetworks.com/articles/Solution/Users-randomly-lose-network-and-internet...
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 50,226 Points 50k badge 2x thumb
Hi Doug,
any update on the release date - I've a upgrade window tomorrow and would prefer 9.21.07 over 9.21.06.
Thx,
Ron
Photo of JP
JP
Any update on the 9.21.07 code ?
Photo of Doug Hyde
Should be posted on or before 3/2
Photo of Ron Oley
Ron Oley
9.21.07 did not solve the issue for us.  It changed it slightly; now we can't ping anything at all when it happens instead of not being able to ping host addresses before.
(Edited)
Photo of JP
JP
How often is the problem happening for you ?  We have been getting reports of students having internet problems, but the more I talk with them, it seems like it is more wide-spread for us than I originally thought.   Disappointed to here that 9.21.0.7 did not fix the ongoing issue.  What's next ?
Photo of Doug Hyde
We have many beta test accounts where code 9.21.07 has fixed connection issues. I would suggest anyone that is still having issues post 9.21.07 to please contact or continue to work with GTAC support to iron out any site specific problems.
Photo of Ron Oley
Ron Oley
It happens often.  We have hundreds of open calls, with most of those users being affected daily.
(Edited)
Photo of JP
JP
Are you able to tell in anyway on the back-end through AP traces/logs or anything like that when it happens ?   I originally thought our problem was limited to 2.4ghz, but I think that was another issue that was corrected in earlier 9.21 code.  We have had some students express frustration with wifi at times recently and I have been working with them and it seems like most of them point back to the issue discussed here.
Photo of Ron Oley
Ron Oley
Nope, the only way to see it for sure is to catch a client while it's failing.  It's often working by the time we get to the room, and fails again just after we leave.  Very frustrating.
Photo of James A
James A, Embassador
  • 7,338 Points 5k badge 2x thumb
The traces I have show hostapd thinking it sends out a response to EAPOL start, but you never see it in the air, and so auth times out. For us it's reliable, once an AP is broken all 802.1x clients will be broken on it. Also it takes a day or so after a reboot to start happening, so for a while I was rebooting all APs overnight.
I'm trying downgrading to 09.21.03 while I wait for this to be fixed - there was a similar problem with no EAPOL response that was supposedly fixed in 09.21.04, but it was at least less frequent.
Photo of JP
JP
Are you on 9.21.07 also ?
(Edited)
Photo of James A
James A, Embassador
I have 09.21.07.0005, which does at least fix 802.11r-related crashes on AP3825 (although I have 11r turned off now for the time being anyway).
9.21.07.0007 is released and available for download on the server
Photo of FES
FES
  • 1,360 Points 1k badge 2x thumb
We have the same problem. 480 ap's and two controllers V2110 with 3805i and 3825i... the situation is frustrating.
we are in 09.21.5 in controller but in some buildings we have installed a 9.21.07.0002, but the problems persists.
does th 09.21.07.0005 solve de problem?
are there any way to reboot all the aps automatically overnight?
regards
I hope that the update is published as soon as possible...
Photo of Doug Hyde
9.21.07 is on our GA download site now. The beta build you have was our first attempt at the fix. The GA build has the most current update fixes in it.
Photo of JP
JP
Wondering if the controller type plays a role in this at all ? I have not upgraded yet (still on 9.15.x), but have 5210's.  I have gotten some reports of the issue, but am wondering if it was not as bad in 9.15 or maybe the controller type plays a role in some way.
Evan Kuckelheim
Just upgrade to 9.21.07.0007 Lets see if this does the trick.
Photo of James A
James A, Embassador
I'm going to 9.21.07.0007 now as well, 09.21.03 had various dropouts.
Photo of Jon
Jon
  • 60 Points
Any comments from those who have tried the GA 9.21.07.0007 ? Has it helped any of the connectivity problems noted ?
Photo of James A
James A, Embassador
I've had no problems so far, but it normally takes a day to start happening and I only upgraded my APs last night.
Photo of Rob Frazee
Rob Frazee
  • 62 Points
Has the update fixed the problem?
Photo of James A
James A, Embassador
Not for us, still not seeing EAPOL reply packets in the air although hostapd claims to have transmitted them. I've got an engineer on-site so we'll see what he comes up with.
Photo of FES
FES
thanks por the article Roland!!
Evan, do you know when the upgrade will be published?
thanks for the help
