X440-G2 PoE capacity
  • Question
  • Updated 2 years ago
  • Answered
Hi all
I'm trying to (unsuccessfully) work out from the datasheet how much power is available for PoE on an X440-G2-48p without the additional RPS connected.  This is well documented on the X450-G2 datasheet for the X450-G2 product set, but it seems lacking for the X440-G2.
Is this listed anywhere / can someone let me have a number?
Thanks
Paul.
Photo of Paul Thornton
Paul Thornton
  • 1,424 Points 1k badge 2x thumb
Posted 2 years ago
Photo of Adilson Gal
Adilson Gal, Employee
  • 1,408 Points 1k badge 2x thumb
Hello Paul,
I believe the information you are looking for is available at the technical specifications of the hardware installation guide. See PoE+ Power Budget section.
I hope it helps.
