x450a SNMP Temp sensor not updating
  • 2
  • Problem
  • Updated 1 month ago
  • Solved
My SNMPv2 monitoring server is set to monitor OID (snmp temp sensor) on an extreme x450a (version
The problem:
- When the server queries the switch, the switch always reports the same temperature.
- When I log into the switch (CLI) and run "show temp" or "show snmp get <OID>" I see the correct temp.
- The next time my monitoring service queries the switch, it reports the new temp.
Wireshark captures confirm the packet coming back from the switch is the old stale value.
Not sure if the switch is caching this or what. Is there a way to fix this?
Photo of Kaon Thana
Kaon Thana
  • 256 Points 250 badge 2x thumb
Posted 1 month ago
  • 2
Photo of Karthik Mohandoss
Karthik Mohandoss, Employee
  • 5,376 Points 5k badge 2x thumb
Hi Kaon,
This bug is fixed from
12.x EXOS versions are end of support, i would recommend to take a look at the below link and upgrade to supported and stable version of EXOS.
