XMC device license violation
  • Question
  • Updated 3 months ago
  • Answered
What will happen when I add 26th device in XMC when I have NMS-25 license?
Photo of LukiM
LukiM
  • 120 Points 100 badge 2x thumb
Posted 3 months ago
Photo of LukiM
LukiM
One more thing. Where to check what type of license is on XMC applied and how many devices are supported on this deployment?In Administration->Diagnostics->Server License there is only a license key without the number of devices supported.
Photo of Ronald Dvorak
Ronald Dvorak, Embassador
  • 48,954 Points 20k badge 2x thumb
the License# includes the type.
i.e. mine starts with 0001:NMS-ADV-U:xxxxx
ADV = advanced
U = unlimited devices
Photo of SH
SH
  • 4,204 Points 4k badge 2x thumb
Hello,
one device more will work.
Best regards,
Stephan
Photo of LukiM
LukiM
Thanks for the reply. Do you know what happens when you exceed more? Do you get some kind of warning or do the system stop working or what is the behavior of XMC?
I am asking cause sometimes, the procedure of buying the upgrade for more devices takes longer then the time you need to implement those devices to XMC and EAC so it would be nice to know before hand, behavior of the XMC like we do with the EAC and 4 stages before you get "Catch all" rule still passing users.
Photo of Brian Anderson
Brian Anderson
  • 722 Points 500 badge 2x thumb
I think it will allow 5 more devices than the license then you can't add any more.  At least that has been my experience.
