Extreme Management - Connect
‎01-22-2018 07:34 AM
Hi Community
Recently I saw some posts referring to the "Distributed IPS" module in "one Fabric Connect".
Without this post I would never have known about this "GREAT" feature.
It opens up alot of sales opportunities.
It would really be great to see an document explaining each "Connect" module in detail:
1. use case
2. Config example
And then keep the community updated on any new modules added.
Thx
1. use case
2. Config example
Thx
4 REPLIES 4
‎06-21-2018 04:52 AM
Thank you SH
‎06-19-2018 01:11 PM
And in documentation section you can find this PDF:
https://documentation.extremenetworks.com/netsight/8.1/9035441_ExtremeConnect.pdf
Best regards
Stephan
Best regards
Stephan
Regards
Stephan
‎06-19-2018 01:06 PM
Hello Andre,
you can see a lot of details to the REST-API here:
http://nms.extremewireless.ca:8080/Clients/help/content/oneview/docs/connect/docs/c_ov_connect_main....
Best regards
Stephan
Best regards
Stephan
Regards
Stephan
‎06-19-2018 12:46 PM
Hi Community
I am back on the XMC Connect TAB and available plugins ect.
1. use case
2. Config example
Enough likes to this post and we might just see this type of document.
1. use case
2. Config example
