7522 antenna question
gluo
New Contributor II
The antenna guide in page 28 lists all the compatible antennas for AP7522 EMEA.
For Patch antennas there is a (*) for ML-2452-PTA3M3-036 which has three(3) connectors.
How should this be connected on the AP7522e which only has two(2) RP-SMA ports? What should the antenna mode be set in the config of the radios?
Why ML-2452-PTA2M2-036 which has two(2) connectors is not available?
The same question goes for antenna ML-2452-PTA6M6-036 which has six(6) ports.
Thank you in advance.
0 REPLIES 0
