ā03-29-2020 03:59 PM
I've been using Aerohive for years at work, and have also purchased a couple AP122 for my home. Now that WPA3 is available, I've been trying to do some testing, but things aren't going well.
I'd really like to get WPA3 working correctly, and be able to (at the very least) configure the other SSID's for WPA2 only, since WPA-TKIP is unsecure and I'd like to disable it.
Thanks for ANY help.
ā03-30-2020 11:57 AM
I'd like to get a look at the connection details, would you be able to enable auth debugs, try to connect to the primary VLAN with WPA3 mode enabled using the Intel AX200 device, then pull tech data and send that file along with the MAC address of the Intel AX200 device to me at communityhelp@aerohive.com?
This guide reviews how to enable auth debugs: https://thehivecommunity.aerohive.com/s/article/Authentication-Auth-Debugs
This guide reviews how to get tech data from the CLI of the AP: https://thehivecommunity.aerohive.com/s/article/Collecting-Tech-Data-via-CLI
