External CWP with mac-auth and CWP bypass. Users still have to open CWP even though user profile is allowall.
mickwombat9
I am trying to setup an external captive portal but with mac-auth. I have a user profile for users that have already registered (allowall) and set this in 'apply different user profile for different groups based on Filter-ID'.
When the user does the mac-auth, I see it with the allowall profile, but I still get redirected to the captive portal.
User profile application sequence is set to mac-auth > CWP > SSID.
Has anyone else setup something like this before.
1 ACCEPTED SOLUTION
nlowe
New Contributor III
Hi all,
I think you just need to configure the fallback-to-ecwp command via supplemental CLI.
I double checked HiveOS 6.5r10 and this is supported there.
You will need to find the name of the security-object by reviewing the show run output.
show cmds | include fallback-to-ecwp
security-object <string> security additional-auth-method mac-based-auth fallback-to-ecwp
show version
Aerohive Networks, Inc.
Copyright (c) 2006-2018
Version: HiveOS 6.5r10 build-205308
Build time: Wed Aug 8 10:22:25 UTC 2018
Build cookie: 1808080322-205308
Platform: HiveAP330
Bootloader ver: v1.0.3.4d
TPM ver: v1.2.35.8
Uptime: 13 weeks, 3 days, 13 hours, 44 minutes, 32 seconds
Thanks,
Nick
20 REPLIES 20
sstowell
I had an issue with CWP bypass via user profile as well. All of my APs were on 6.X HiveOS.. I have a mix of AP121s, 130s, and 230s.. Well I updated all of my APs that I could to 8.X hiveOS (golden) and the bypass now works via user profile on my AP130s and AP230s..
Well guess what? AP121s are not getting HiveOS 8.X and are stuck on 6.X.. so now I have about half my APs as 121s and cannot use that feature until I upgrade them to new APs 130s or 122s. That's about 40 APs. I understand they are a little dated but it's ridiculous to think they cannot get the newest code to do this bypass, it's not like it needs new hardware to do it.
irteza_rana
Aerohive has one of the worst tech supports, the idiots at tech support were recommending me to turn off CWP.
I have similar issue where users would keep on getting CWP. I have also tried adding fallback-to-ecwp  via supplementary cli but it didn't work. I did confirm that aerohive NG is getting correct radius attributes required by user profile to bypass CWP.
I have a case open with them for a month and they still dont have any clue regarding this issue.
samantha_lynn
Esteemed Contributor III
I think at this point we need to open a support case to dig in to this further with you. I have emailed you directly with details on how to open a case from here so the technician can begin where we have left off.
mickwombat9
ok, so I tried that and now nothing seems to work. I see the mac.auth going through and it sending back the correct user-profile attribute, but the device gets dissassociated due to a vlan change. This is strange because every possible user-profile for this ssid is set to the same vlan.
2018-12-20 11:10:47 info   ah_auth: sta 6cc7:ec0c:d893 is disassociated from 4018:b1ae:b8e8(wifi1.1) in driver
2018-12-20 11:10:47 info   ah_auth: [Auth]: receive driver notification[0x8c04, IWEVEXPIRED] for Sta[6cc7:ec0c:d893] at Hapd[4018:b1ae:b8e8, wifi1.1]
2018-12-20 11:10:47 info   ah_auth: Notify driver to disassoc 6cc7:ec0c:d893 from wifi1.1
2018-12-20 11:10:47 info   ah_auth: Disconnect 6cc7:ec0c:d893 because VLAN change after UPID reassignment
2018-12-20 11:10:46 info   ah_auth: detect station(6cc7:ec0c:d893) os(Android) via DHCP fingerprint
2018-12-20 11:10:45 info   ah_auth: detect station(6cc7:ec0c:d893) os(Android) via DHCP fingerprint
2018-12-20 11:10:45 info   kernel: [qos]: add qos user 6cc7:ec0c:d893 idx 3 uppid 1
2018-12-20 11:10:45 info   kernel: [mesh]: set proxy : 6cc7:ec0c:d893 4018:b1ae:b8c0 wifi1.1 flag 0x1c03
2018-12-20 11:10:45 info   amrp2: set proxy route: 6cc7:ec0c:d893 -> 4018:b1ae:b8c0 ifp wifi1.1 upid 3 flag 0x1c03 monitor(0/0) pkt/sec ok
2018-12-20 11:10:45 info   amrp2: receive event <STA join>: 6cc7:ec0c:d893 (ip 0.0.0.0) associate wifi1.1 upid 3 vlan 13 flag 0x00000001
2018-12-20 11:10:45 info   ah_auth: [Auth]STA(6cc7:ec0c:d893) login to SSID(wifi1.1) by user_name=6cc7ec0cd893
I am using an AP121 on HiveOS 6.5r10 build-205308
nlowe
New Contributor III
Hi all,
show version
Platform: HiveAP330
TPM ver: v1.2.35.8
Thanks,
Nick
