‎02-05-2019 06:38 PM
‎02-05-2019 07:08 PM
Yes. HTTPS 443 is allowing outbound traffic. See output from switch ref clock
(AH-Switch) #show clock
14:07:11 EST(UTC-5:00) Feb 5 2019
No time source
(AH-Switch) #show app
OpEN Application Table contains 1 entries.
Name StartOnBoot AutoRestart CPU Sharing Max Memory
hiveagent Yes No 0 0
‎02-05-2019 07:00 PM
Thank you for that information. Can you confirm that HTTPS 443 is allowing outbound traffic via your firewall and any content filters? Some additional things we could try:
1) If you run the command "show clock", is the date and time displayed correct?
2) Confirm that HiveAgent is installed correctly with the command "show application".
Just to confirm, the switch used to connect to the HiveManager but then disconnected? Did anything change on the network directly before the switch disconnected? When did you first notice that the switch was disconnected?
‎02-05-2019 06:53 PM
Switch model SR2208P.
The HiveManager that the AP is connected to, and that the switch was formerly connected to is HiveManger (formerly NG) cloud-va2.aerohive.com.
This is status on switch on CLI.
HiveAgent Status............................... FAILED TO CONNECT TO REDIRECTOR/HIVEMANAGER, WAITING BEFORE TRYING AGAIN
HiveAgent Version.............................. 1.1.4.0
HiveAgent Last Onboard Time.................... 00:01:02 10 12 2017 UTC
‎02-05-2019 06:47 PM
What model switch are you using? And which HiveManager platform are you trying to connect it to; HiveManager Classic (myhive.aerohive.com) or HiveManager (formerly NG, cloud.aerohive.com)?
