Is there a way in Hive Manager NG to adjust power levels on multiple access points to try and clean up radio interference? This could be done in classic but does not appear to be available in NG?
‎02-03-2020 03:44 PM
‎02-05-2020 02:01 PM
I made the same mistake Ron, they changed the interface look and I missed that we had to specify the radio is on, since it already was on. Sorry for the confusion, thanks as always Ashley!
‎02-05-2020 01:27 PM
I stand corrected. You are right, Ashely. The option is there if you click on the radio to turn it on or off. When I do that the option for manual power settings and the slider for power setting becomes available. Thank you for saving me a mountain of time.
That was not an apparent thing to me as the radio is already turned on. Why would I think of turning it off and back on to change the power setting? Sometimes the most obvious things are those you do not see.
That said, the classic hive manager had a much cleaner way to handle this.
Thank you again and have a great day!
‎02-05-2020 09:59 AM
Correct me if I'm wrong but you can do this currently?:
If you select multiple APs on the manage page > edit > interface settings > expand wireless interfaces > change radio status to on > change TX power to manual > select value > save
‎02-04-2020 04:10 PM
I completely understand, the templates are not an ideal way to manage individual power level changes, and many networks do need to adjust the power on an case by case basis. I would encourage you to submit a feature request with your Aerohive Sales Engineer to see if we can add that feature back to the Manage/Monitor tab in the GUI. I've emailed you directly with your Sales Engineers contact information, please let me know if I can help with anything else.
