Is there a way to use emoji for the ssid using Connect? (I have tested this using the cli and it works out well.)
lordbink
8 REPLIES 8
lordbink
Simple examples:
There are non-emoji examples that are also unicode (which also do not seem to work):
עשה את הנדרש
不要激怒猴神
воняет как волшебство
それをググってみましょう
For reference:
samantha_lynn
Esteemed Contributor III
Can you send me the characters you're trying to use so I can test this in our lab?
lordbink
It looks like the web interface for Connect does not allow all unicode characters in the SSID name that are allowed by the 802.11 specification. It is basically a unicode character that is interpreted as an image. You can use unicode characters like Chinese and Spanish images in the SSID name and devices will interpret it correctly (that adhere to the standard properly).
samantha_lynn
I'm sorry, I'm not sure what you're asking. Are you trying to use an image for the SSID name?
