My AP230 is stuck on red light and does not connect to the hivemanager.
‎03-25-2019 06:54 AM
I don't know how to get it fixed and how to diagnose ? Should I press the reset button ?
How can I load the configuration then?
How can I get support from Aerohive?
SN: 02301512142355 / MAC:D854A27B91C0
Any help would be welcome!
‎03-25-2019 03:25 PM
Please write back if you're still having issues. Simply put, your AP us unable to establish a capwap connection to Hivemanager, either due to layer two issues (VLANs), layer three issues ( ip addressing and /or routing), or layers 4-7 (firewalling). We'd love to help you determine which it is and help correct it.
‎03-25-2019 01:07 PM
Resetting the device is one option for troubleshooting a device that can't connect, the following guide will walk you through other troubleshooting steps you can take and some commands you can use to manually connect the device to the HiveManager, depending on which HiveManager platform you are using:
HiveManager Classic (myhive.aerohive.com):https://thehivecommunity.aerohive.com/s/article/CAPWAP-HiveManager-Classic
HiveManager (formerly NG, cloud.aerohive.com):https://thehivecommunity.aerohive.com/s/article/CAPWAP-Guide-for-HiveManager-NG
This guide will walk you through how to add the device to your HiveManager inventory. We'll need the device to connect to the HiveManager so we can push configuration updates out to the device.
HiveManager Classic (myhive.aerohive.com):https://thehivecommunity.aerohive.com/s/article/Adding-Devices-in-HiveManager-Classic
HiveManager (formerly NG, cloud.aerohive.com):https://thehivecommunity.aerohive.com/s/article/Adding-and-Removing-Devices-in-HiveManager
For support, that depends on the support contact you purchase. I believe your account has partner support, so you would want to reach out to the Aerohive partner you purchased from for first level support. If you're unsure who to contact for your partner, please feel free to email me at communityhelp@aerohive.com, and I can give you some contact information for your account specifically.
