"External Antenna" settings for 35° Directional Antenna
AnonymousM
Valued Contributor II
We're installing several for 35° directional antenna's (Ventev's TerraWave High Density 14 dBi Patch Wi-Fi Antenna, link below) outside on the AP1130. What would we set the "External Antenna" settings to?
http://www.ventevinfra.com/shop/font-colororangenewfont-245-ghz-14-dbi-high-density-patch-antenna-with-nstyle-jack-connectors-p-2993.html
1 ACCEPTED SOLUTION
GeorgiaMason
Contributor II
I think you'd be limited to "other". If you run the command "interface wifiX radio antenna antenna type ?" it shows all the options available for external antenna's. Other seems to be the only non-Aerohive related option.
Output:
AH-0cde00#interface wifi0 radio antenna type
  omni      Set the antenna type to be Aerohive-certified
          omnidirectional for point-to-multipoint wireless links
  other     Set the antenna type to be any other antenna that is not
          certified by Aerohive
  sector-120  Set the antenna type to be Aerohive-certified 120-degree
          sectoral for point-to-multipoint wireless links
  sector-60   Set the antenna type to be Aerohive-certified 60-degree
2 REPLIES 2
AnonymousM
How would the "External Antenna" settings change the AP's behaviour when choosing the "other" option vs. to the "omni" option?
GeorgiaMason
Contributor II
Output:
