ā09-06-2018 02:22 PM
Solved! Go to Solution.
ā09-06-2018 02:53 PM
This indicates you have Radio Frequency interference on your network. The following guide will help you troubleshoot this, depending on what HiveManager platform you are using.
HiveManager Classic (myhive.aerohive.com)- https://thehivecommunity.aerohive.com/s/article/Radio-Frequency-Interference-Troubleshooting
HiveManager (formerly NG, cloud.aerohive.com)- https://thehivecommunity.aerohive.com/s/article/Radio-Frequency-Interference-NG
ā05-21-2019 09:46 PM
We are also see a lot of continuous errors " wifi0: A high interference alert was raised" on all our AP230 and AP250, when we upgraded to the latest firmware "HiveOS 8.4r10.219856". Any suggestions?
ā04-30-2019 08:57 PM
Thank you for that data, but unfortunately both files are showing they are from a device on HiveOS 8.2r4. Could you update to the latest, get tech data from that version, then if the issue is still present downgrade to a version that does not have this issue and send tech data from that set up as well?
ā04-30-2019 07:13 PM
I just sent you an email with the requested data.
ā04-30-2019 06:14 PM
Yes, can you update to the latest and see if the problem is still present?
ā04-30-2019 06:09 PM
the HiveOS version 8.2r5.221111 for me is lasted a golden for me in myhive is HiveOS 8.2r4.207023
