‎06-27-2018 02:17 PM
I have created a network policy on the HiveManager NG cloud, but my clients are not getting DHCP addresses. I tried to do the VLAN Probe and it says my VLAN's are not available.  Please help. I tried checking all layers. I can connect to the AP via ssh and can ping other networks from the AP, but my clients aint getting DHCP ips
Solved! Go to Solution.
‎07-02-2018 03:07 PM
Hi Thabiso,
Thank you,
Could you go to the CLI of the AP with a Terminal Client like Putty(Windows) or OpenSSH admin@ip-of-AP
HowTo: https://thehivecommunity.aerohive.com/s/article/How-to-Connect-to-an-AP-using-SSH
Please try this command:
int mgt0 dhcp-probe vlan-range 340 340
Then, this command as well:
int mgt0 dhcp-probe vlan-range 350 350
They Should Pass If all is tagged up-stream and DHCP is properly configured.
If Not, we can continue Triage:
So far, you've confirmed the Switch-Port that the AP is connecting to Tags correctly.
Are you using vLAN 340 or 350 for the User-Profiles, or both?
If so, then the DHCP Probe commands above should have passed but if they fail, We'll want to locate where the drop is.
Please perform a Client Monitor with the MAC Address of the client device that's failing. We will want to determine which part of the DHCP Handshake is failing, OR if the problem is Radio Association.
Client Monitor: https://thehivecommunity.aerohive.com/s/article/Client-Monitor-in-NG
Hope this helps,
David Souri
HiveCommunity Moderator
‎06-27-2018 04:57 PM
If VLAN probe is showing the VLANs are unavailable, that means that either the DHCP scopes are not setup/enabled or that there is a network infrastructure configuration problem. Assuming that the DHCP scopes are setup and configured correctly, let's look at the network infrastructure. The most likely issue is that the port on the switch that the AP is plugged into is not tagged for the VLANs that you need. Check the configuration of the switch port that the AP is on and make sure that it has the VLAN tags for the appropriate VLANs.
