02-26-2021 09:32 PM
Hi
Im facing some problem with BGP on SLX9740
BGP is configured but:
show ip bgp summary all-vrfs
VRF: default-vrf
BGP is not operational
VRF: RKPM01
VRF: RKGM01
Below configuration for router bgp
show running-config router bgp
router bgp
capability as4-enable
address-family ipv4 unicast
address-family ipv4 unicast vrf RKGM01
local-as 11111
neighbor 192.168.52.1 remote-as 1111
neighbor 192.168.52.1 maximum-prefix 999999
neighbor 192.168.52.1 prefix-list EPIX-no-advert out
neighbor 192.168.52.1 route-map in KRPM1-BGP-in
neighbor 192.168.52.1 route-map out KRPM1-BGP-out
neighbor 192.168.52.1 description KRPM1-BGP
neighbor 192.168.52.1 next-hop-self
neighbor 192.168.52.1 remove-private-as
neighbor 192.168.52.1 soft-reconfiguration inbound
neighbor 192.168.52.1 update-source 192.168.52.3
address-family ipv4 unicast vrf RKPM01
local-as 11111
address-family ipv6 unicast
address-family ipv6 unicast vrf RKGM01
address-family ipv6 unicast vrf RKPM01
address-family l2vpn evpn
trying to show summary for vrf BGP:
show ip bgp summary vrf RKGM01
But show ip bgp neigh at vrf
show ip bgp neighbors vrf RKGM01
Total number of BGP Neighbors: 1
'+': Data in InQueue '>': Data in OutQueue '-': Clearing
'*': Update Policy 'c': Group change 'p': Group change Pending
'r': Restarting 's': Stale '^': Up before Restart '<': EOR waiting
1 IP Address: 192.168.52.1, AS: 1111 (EBGP), RouterID: 0.0.0.0, VRF: RKGM01
Description: KRPM1-BGP
State: IDLE, Time: 2h55m2s, KeepAliveTime: 60, HoldTime: 180
Minimal Route Advertisement Interval: 0 seconds
UpdateSource: Address 192.168.52.3
NextHopSelf: yes
RemovePrivateAs: : yes
SoftInboundReconfiguration: yes
Address Family : IPV4 Unicast
MaximumPrefixLimit: 999999
Prefix-list: (out) EPIX-no-advert
Route-map: (in) KRPM1-BGP-in (out) KRPM1-BGP-out
Messages: Open Update KeepAlive Notification Refresh-Req
Sent : 0 0 0 0 0
Received: 0 0 0 0 0
Last Connection Reset Reason:Unknown
Notification Sent: Unspecified
Notification Received: Unspecified
Neighbor NLRI Negotiation:
Peer configured for IPV4 unicast Routes
Neighbor ipv6 MPLS Label Capability Negotiation:
Neighbor AS4 Capability Negotiation:
Peer configured for AS4 capability
Outbound Policy Group:
ID: 1, Use Count: 1
BFD:Disabled
Error: TCP status not available
Maintenance Mode : Disabled
G-Shut: Disabled
Solved! Go to Solution.
02-26-2021 09:49 PM
02-26-2021 09:56 PM
Yes thank You - it was exactly this…
There need to be some changes made in manual 🙂 because I was trying to search some “enable bgp service”
Because for me there will be no BGP normally used in vrf default - that is why I didn’t configured any local-as for that vr - just for other vrf’s
Thank You again.
02-26-2021 09:53 PM
See above, I just edited it :-), you have been too quick 🙂
You need configure a local-as in the router bgp global.
02-26-2021 09:51 PM
shoyes:
vrf RKGM01
max-route 3000000
max-route 3000000
ip router-id 10.10.10.1
interface Loopback 1
vrf forwarding RKGM01
ip address 10.10.10.1/32
no shutdown
02-26-2021 09:49 PM
→ see down under
