how to enable/disable trial license in extreme ware switches summit 400-24P ?
‎11-07-2015 05:26 AM
Need to enable & disable trial License in Extreme Ware Summit 400-24P switch.
"show switch" output shows : License: *** ILLEGAL Advanced Edge ***.
Software Version: Primary EW Ver: 7.8e.4.1 [non-ssh]
6 REPLIES 6
‎11-07-2015 05:37 AM
Hello Jitendra,
I hope the below article may help you for the same:
https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-enable-trial-license/
‎11-07-2015 05:33 AM
Hello Jitendra Patel,
You can clear the license information by execute the below command:
#clear license-info
If the switch you are using is on a trial license, you will need to use an alternate command to clear license information on the switch.
#debug epm clear trial-license
Hope this will help you!
#clear license-info
