Aki_Tooley
Notice Summary:
Three critical defects affect EXOS 33.7.1.6, its patch builds, 32.7.4.15, and 33.6.1.14. There are IGMP reports not being processed (CFD-18354), duplicate forwarding and Layer 2 loops in MLAG environments (EXOS-39960), and 5520/5420 switches that sometimes hang during boot (CFD-17913). All three are fixed in EXOS 33.7.1.6-patch1-32, which is now the recommended 33.7 release. Customers on the affected releases should plan to upgrade.
Background:
Each defect was found after the affected release shipped and each appears only under specific conditions, although the releases are widely deployed:
Defect
Issue
Introduced In
Condition
CFD-18354
IGMP report packets with the Router-Alert option are ignored
EXOS 33.7.1.6 and 32.7.4.15
Switch in software-learning mode with Netlogin enabled
EXOS-39960
Packet blocking does not work correctly in MLAG environments
EXOS 33.6.1.14
Stacking with MLAG, where the MLAG port and ISC ports are in different slots and the MLAG egressMask ACL does not work properly
CFD-17913
Boot does not complete at random times
EXOS 33.7.1.6
5520 and 5420 switches during a reboot or upgrade; occurs randomly, not on every boot
Impact:
  • CFD-18354: On affected platforms in software-learning mode with Netlogin enabled, IGMP reports with the Router-Alert option are ignored. Multicast group membership may not be learned, so multicast traffic may not reach receivers that have joined.
  • EXOS-39960: In MLAG environments (stacks where the MLAG port and ISC ports are in different slots), duplicate packets can be forwarded and Layer 2 loops can form. A loop can cause a network-wide outage.
  • CFD-17913: A 5520 or 5420 switch can get stuck booting after a reboot or upgrade. The hit rate is about 5% of reboots or upgrades and an affected switch is unavailable until it is recovered through console.
Products Affected:
Defect
Platforms
CFD-18354
ExtremeSwitching 7720, 7520, 5720, 5520 and 5420
EXOS-39960
Stacks of 7720, 7520, 5520 and 5420
CFD-17913
5520 and 5420
Software Affected:
Defect
Affected Releases
Fixed In
CFD-18354
EXOS 33.7.1.6, 33.7.1.6-patch1-11, 32.7.4.15, 32.7.4.15-patch1-11
33.7.1.6-patch1-26; 32.7.4.15-patch1-14
EXOS-39960
EXOS 33.6.1.14, 33.7.1.6, 33.7.1.6-patch1-11
33.7.1.6-patch1-32
CFD-17913
EXOS 33.7.1.6, 33.7.1.6-patch1-11, 33.7.1.6-patch1-26
33.7.1.6-patch1-32
Symptoms:
  • CFD-18354: When the switch is in software-learning mode with Netlogin enabled, IGMP report packets that carry the Router-Alert option are ignored, so multicast group membership is not learned.
  • EXOS-39960: In an MLAG environment, packet blocking does not function correctly. This results in duplicate packet forwarding and Layer 2 loops.
  • CFD-17913: A 5520 or 5420 switch can get stuck in a booting state after a reboot or an upgrade to 33.7. It happens at random, and the observed hit rate is about 5% of reboots or upgrades.
Workaround:
No workaround is available.
Solution:
Upgrade to the fixed release:
  • EXOS 33.7: Upgrade to EXOS 33.7.1.6-patch1-32, available on the Extreme Portal. It fixes CFD-18354, EXOS-39960 and CFD-17913.
  • EXOS 32.7: Upgrade to EXOS 32.7.4.15-patch1-14 once it is posted to the Extreme Portal. It fixes CFD-18354, the only one of the three that affects 32.7.
Please see the full Field Notice here for more details and future updates.
1 Comment
Stefan_K_
Valued Contributor
This is posted 3 Months / 8 Months after the bugs have been "introduced" and 2 months after the final fix has been released. I don't understand this.
