ā09-03-2020 07:01 PM
We are replacing Cisco Wireless Controller with Extreme Campus Controller for one customer. The customer wants to continue with External Captive Portal they have on Cisco. For some reason, this captive portal is not working for XCC and distributor of captive portal told us that they need to develop their captive portal further in order to make it work with XCC. We do not have that much time. We had another customer who had issue with External Captive Portal and they are still struggling with it. We were told by Extreme that the new version of XCA/XCC would resolve that issue.
I wanted to know if there is any External Captive Portal that provides sms code for authentication and is compatible with XCC?
Solved! Go to Solution.
ā09-30-2020 10:46 AM
You can also use any firewall having captive portal capabilities. In this case we bridge the SSID to a VLAN authenticated with a captive portal.
The advantage to go for an Extreme solution is to have the integration already done and the management consolidated.
Mig
ā09-30-2020 05:13 AM
Hi Santosh,
You can check ExtremeGuest, which is Extremeās own Captive Portal and Guest Analytics solution. It is compatible with XCC and as a matter of fact, the integration is very simple. ExtremeGuest provides Social Media, Email, SMS and self-registration options for Guest onboarding.
Check out this guide:
ExtremeGuest and XCC integration
