12-05-2019 08:10 PM
I’m looking for a CLI guide for the Defender devices.
12-06-2019 01:50 PM
You can run ‘cget config global’ to see your config settings. To see just the ip address you set for the article above you can run this command: cat /home/config/current.cfg | grep "cset auth" to get just those settings.
Also you can run tail -f /tmp/log/ap.log and see what the ap is currently doing, like trying to connect to the wireless controller.
12-05-2019 09:54 PM
I’m trying to troubleshoot a Defender (SA201) device. I’m trying to configure the SA for external (to our network) use using this article https://gtacknowledge.extremenetworks.com/articles/How_To/How-to-configure-controller-s-IP-in-the-AP...
Currently the only remediation I have is a factory reset. I’m looking for commands to verify what I have entered or other basic commands...
12-05-2019 08:54 PM
The base product for Defender Application is ExtremeCloud Appliance. We do not fully support a CLI on ExtremeCloud Appliance. Instead, we encourage use of the REST API, which is fully documented. See https://extremenetworks.com/documentation/extremecloud-appliance for REST API documentation.
If you are referring to the adapter SA201, we do not have CLI definition on the AP39xx/SA201.
