‎02-13-2020 11:13 AM
The certificate received from the remote server was issued by an untrusted certificate authority. Because of this, none of the data contained in the certificate can be validated. The TLS connection request has failed. The attached data contains the server certificate.
Solved! Go to Solution.
‎02-18-2020 08:10 AM
Because of the use of a specific wireless interface this issue has raised.
the network card is a : Intel dual band wifi AC adapters.
When using another laptop with another network card this issue is not raising.
So problem is solved.
‎02-13-2020 01:43 PM
If you don’t want to use 802.1X then you can’t use the WPA2-Enterprise (802.1x/EAP) WLAN service.
I’d assume you use username/password = EAP-PEAP which requires a server certificate as per 802.1X standard.
In that case you’ve the two options I’ve mentioned = a trusted certificate on the XCA or disable certificate verification. on the clients.
-Ron
‎02-13-2020 12:57 PM
But I do want to use 802.1x because my radius server (Identity engine) is doing authentication for the users here.
I do not want to handle any certificates. Can I disable that in VE6120 somewhere….
thanks
‎02-13-2020 12:40 PM
But that is how 802.1X works in that case.
To avoid it pay for a trusted certificate and upload it and you don’t run into this FAD issue.
-Ron
