VE6120 certification not trusted on pc - no wifi connection.
Sacha_Brys
Contributor
The certificate received from the remote server was issued by an untrusted certificate authority. Because of this, none of the data contained in the certificate can be validated. The TLS connection request has failed. The attached data contains the server certificate.
1 ACCEPTED SOLUTION
Sacha_Brys
Contributor
Because of the use of a specific wireless interface this issue has raised.
the network card is a : Intel dual band wifi AC adapters.
When using another laptop with another network card this issue is not raising.
So problem is solved.
7 REPLIES 7
Sacha_Brys
Contributor
Hi, thanks
The WLAN service is a WPA2-Enterprise (802.1x/EAP).
But this is not a good solution to disable at the client site the certification verification.
Ronald_Dvorak
Honored Contributor
What kind of WLAN service are we talking about ? i.e. guest splash, WPA enterprise
You are able to disable certification verification on the client site in most cases.
i.e. Google ā€œdisable validate server certificate windowsā€
-Ron
Sacha_Brys
Contributor
Somewhere, I think, I have to disable the use of certificates in the VE6120.
