5420F not be able to add to TELEMETRY ANALYTICS
EqosSphere-NG
Hi all
It's seems not possible to add on "APPLICATION TEMEMETRY SOURCES" the serie 5420F
We have X440G2 and X460G2 running with analytics
Is it a major problem ?
1 ACCEPTED SOLUTION
NAIM happens to be the default password in a new SE deployment for the SCP / SFTP account credentials under Options -> Inventory Manager -> File Transfer settings.
The script is attempting to pass the password to the CLI of the switch the App Telemetry configuration script is running against.
Confirm you have the correct SCP / SFTP credentials configured. The script is attempting to pull a file FROM XIQ-SE TO the switch which needs to log on to XIQ-SE w/ credentials to do so.
6 REPLIES 6
Zdeněk_Pala
Also check the switch is not unmanaged = it is properly licensed
Firmware version and Site Engine versions can play role also. Was the switch properly recognized or you had to add new Vendor Profile?
Right-click > Configure > Vendor Profile
Regards Zdeněk Pala
Seems to be good
Image : Extreme Networks Switch Engine version 33.1.1.31 by release-manager
on Wed 11 Sep 2024 07:45:46 PM UTC
BootROM : Default 2.3.2.15 Alternate 2.3.2.15
Diagnostics : 0.0.2.5
Certified Version : EXOS Linux 5.10.177, Extreme Networks FIPS Object Module 2.0.16a
Build Tools Version : exos-arm64-sdk-3.1.19.1.0
Robert_Haynes
5420F Switch Engine or Fabric Engine?
In a local setup where the switches are already configured/inventoried in SE I can add both to Analytics without issue. I would have to imagine your switches are missing some critical configuration item.. CLIP address.. MGMT address or the like that SE is not picking up therefore not allowing those to be added as a source.
