5420F not be able to add to TELEMETRY ANALYTICS
EqosSphere-NG
New Contributor II
Hi all
It's seems not possible to add on "APPLICATION TEMEMETRY SOURCES" the serie 5420F
We have X440G2 and X460G2 running with analytics
Is it a major problem ?
1 ACCEPTED SOLUTION
NAIM happens to be the default password in a new SE deployment for the SCP / SFTP account credentials under Options -> Inventory Manager -> File Transfer settings.
The script is attempting to pass the password to the CLI of the switch the App Telemetry configuration script is running against.
Confirm you have the correct SCP / SFTP credentials configured. The script is attempting to pull a file FROM XIQ-SE TO the switch which needs to log on to XIQ-SE w/ credentials to do so.
6 REPLIES 6
The switch has been changed from X440 to a new 5420F with all the same configuration ... the switch is in the device view with about 100 other switches. Some of the X440 / X460 has been added to the ANALYTICS telemetry with success.
But when trying to add the new one (5420F) to the analytics tellemetry source : the error occured :
An error has occurred while adding a telemetry source to the selected engine. See details below for more information.
javax.script.ScriptException: *** Script Error *** Error command issued: Script failed : NAIM Error: session exceeded timeout: 120 secs -> if {! $OverallResult} {:
On the server log :
2024-12-19 14:04:06,869 ERROR [com.enterasys.netsight.appid.server.webapps.monitor.AppIdDwr] Error in step 2 of enabling SFlow+ source for 10.200.128.8
2024-12-19 14:04:06,869 ERROR [com.enterasys.netsight.appid.server.webapps.monitor.AppIdDwr] javax.script.ScriptException:
