8.3 Webshell Copy and Paste not working
Tiburcio_Jr_Cor
New Contributor II
I upgraded to 8.3.3.11 release of XMC and the Webshell copy and paste does not work on Firefox, Crome and Internet explorer.
1 ACCEPTED SOLUTION
Rahman_Duran
Contributor II
Which key combo are you using? I can copy&paste with CTRL+INS and SHIFT+INS without any problem.
3 REPLIES 3
Tiburcio_Jr_Cor
New Contributor II
Yes, it works Thank you. I use Firefox but I will start using Chrome.
PeterK
Contributor III
I would recommend to use chrome for XMC/Netsight. With all other browser a had lots of issues und display problems.
Rahman_Duran
Contributor II
