you can add the controller to NetSight with both SNMP and CLI credentials. then NetSight will configure traps & syslog receiver on controller = you can configure it manually also .
On the controller define the AP poll timeout. When the AP is lost, the controller will report it to NetSight.
All is prepared and easy to deploy.
good luck
Regards
Zdeněk Pala
