yes, we had applied on ingress direction but still, both VLAN can ping each other.
Note If an ACL needs to be installed for traffic that is L3 routed, and the ingress/egress ports are on different packet-processing units or different slots, and any of the following features are enabled, we recommend that you install the policy on a per-port basis rather than applying it as a wildcard, or VLAN-based ACL. ⢠MLAG (Multi-switch Link Aggregation Group) ⢠PVLAN ⢠Multiport-FDB (forwarding database)
