Alarm after dbm drop
‎02-21-2022 07:29 AM
Is there a way to get XMC to notify you when an AP drops to a certain power? for example 5dbm
Thanks, Regards
Thanks, Regards
1 REPLY 1
‎03-26-2022 06:34 PM
Hello,
Not that I know of. XMC can get radio power values for use with heat maps but they aren't included in any statistics collection so threshold alarms won't work.
You could maybe create a workflow that goes out and queries the controller for AP statistics and alarm based on the ouptput.
Thanks
-Ryan
Thanks
-Ryan
