13 hours ago
Hello all.
i have a problem in xmc where all the device type shows as xbox one
i tried to over ride the device type in administration tab and also create a new one but it still did not work.
i will upload a screen shots about what i tried.
any one knows how to fix this ?
Thank you.
8 hours ago
Without enabling DHCP debugging in Control you would just be guessing what DHCP fingerprint string the client is presenting and whether or not it matches the existing Windows device type or whatever the actual device is that's being misrepresented as Xbox One.
The problem with Windows is XBOX and a few other platforms all share similar DHCP fingerprints so identifying them isn't always fool proof.
XMC 8.5.x. is no longer supported / supportable by Extreme so GTAC can not be engaged to assist here unfortunately.
