AP3825i LAG to D2, Netsight/NAC/OneView don't recognize LAG
‎06-19-2015 02:50 PM
My plan was to test the AP3825i LAG function (connected to my D2).
The LAG is up & running so that is working....
D2_desk(su)->show port status lag.0.1
Alias Oper Admin SpeedPort (truncated) Status Status (bps) Duplex Type
lag.0.1 Up Up 2.0G full lag
D2_desk(su)->show mac port lag.0.1
MAC Address FID Port Type
D8-84-66-03-B3-38 100 lag.0.1 Learned
D8-84-66-03-B3-39 100 lag.0.1 Learned
D2_desk(su)->
The issue I observe is that Netsight/NAC/PM/OneView don't seem to recognize the LAG between the AP and D2.
The D2 has MAC auth (allow all) enabled.
- NAC, end-system view show 2 authentication events (ge.1.3&ge.1.5) instead of only one from lag.0.1
- PM, switch detail view only show the phy ports and no LAG so I'm not able to enable auth on the LAG
- OneView, in > wireless > AP view > click on the AP name which should bring up the AP portview
Instead of one view for the LAG two views are opened - one for ge.1.3 and one for ge.1.5.
From here it's get very weird as the first view show the correct AP but the view for port ge.1.5 show a complete different/wrong AP.
Any idea ?
-Ron
D2_desk(su)->
Any idea ?
-Ron
2 REPLIES 2
‎06-19-2015 04:44 PM
Logical ports are hidden in Policy Manager by default. You can show them via Policy Manager menu bar - Tools / Options / Ports, and deselect "Hide Logical Ports"
‎06-19-2015 04:33 PM
AFAIK there is no possibility yo switch on the authentication for logical port. So you will see authentication for all lag member ports. But I'm not sure if it is a good idea to switch on authentication for that port at all. On D2 you have only 2 auth per port so you will not be able to see wireless. If you need to see AP in NAC it is a good idea to limit number of multi auth to one per port.
