‎05-21-2025 12:58 PM
Hi all,
I'm supposed to come up with an inventory of Extreme switches in our network. I can export the device list in the /world site, but it doesn't have members of my stacks. Example: Stack "MyStack" only shows one entry, making it impossible to tell if this is a single switch or a stack.
In my case, all my stacks are ERS.
What options to do I have to come up with a complete list of Extreme switches in my network?
Thanks.
Solved! Go to Solution.
‎05-27-2025 02:57 PM
Thanks Markus. Since this is a workflow, I have downloaded and installed it. I'll probably modify it to give us the info we want.
‎05-22-2025 05:21 AM
If you select a switch, a group of switches or all of them and right-click -> Export Serial Numbers you should be able to export full a full list of devices by IP including modules/slots/serial information (and other sensor/chassis type information). From there you can filter out what you don't need to see what you do.
See
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000116063
https://extreme-networks.my.site.com/ExtrArticleDetail?an=000083011
‎05-27-2025 02:56 PM
This is good, but gives a lot of info. Like you said you can filter it. Thanks.
‎05-21-2025 12:59 PM
I should add, this is for XIQ-SE.
Thanks
‎05-22-2025 06:32 AM
There is a workflow available that pulls all the serials from any component so far the switch type is supported. YOu go to GitHub Extreme Networks.
ExtremeScripting/XMC_XIQ-SE/oneview_workflows at master · extremenetworks/ExtremeScripting
and search for Inventory check
