‎05-21-2025 12:58 PM
Hi all,
I'm supposed to come up with an inventory of Extreme switches in our network. I can export the device list in the /world site, but it doesn't have members of my stacks. Example: Stack "MyStack" only shows one entry, making it impossible to tell if this is a single switch or a stack.
In my case, all my stacks are ERS.
What options to do I have to come up with a complete list of Extreme switches in my network?
Thanks.
Solved! Go to Solution.
‎05-27-2025 02:57 PM
Thanks Markus. Since this is a workflow, I have downloaded and installed it. I'll probably modify it to give us the info we want.
‎05-22-2025 05:21 AM
XTRMUser,
We have used the script from Extreme's GitHub for the License Calculation... That should give you all the devices that require a license in a .csv file. Since each switch needs a license, the switches within the stack show up. You should be able to tell the stack they are in since it also has an IP Address column.
Thanks,
Bill
‎05-27-2025 02:59 PM
I do have this script, but Extreme people loaded it up and used. When I ran it, I had a mysql error on the 2nd step. So I didn't take time to pursue it further. But thanks for the link.
