Automatically delete users/devices from registration portal
‎06-08-2016 01:09 PM
Hi everyone,
is it possible to automatically delete users and devices from the list in registration portal when the defined access time is exceeded?
Stephan
Stephan
2 REPLIES 2
‎06-09-2016 06:03 AM
Hi Scott,
thank you for your answer. I had a look in the settings you mentioned. Unfortunately the setting "Delete expired Users" is missing in Guest Registration. But this is what we need. Also I can't find any option to automatically delete devices.
Regards,
Stephan
Regards,
Stephan
‎06-08-2016 01:44 PM
Hello,
You can delete registered users and their devices from inside the MAC Registration Administration web interface.
There is an article on a similar topic below, on increasing the device count, but the article will tell you how to get to the web interface I am referring to...
https://gtacknowledge.extremenetworks.com/articles/How_To/NAC-How-to-increase-the-maximum-number-of-...
To do this automatically, please look at the setting in the Captive Portal Configuration: Delete Expired Users". This should trigger (if selected) when the registration expires.
Is this what you are looking for?
Regards,
Scott Keene
Extreme GTAC
Regards,
Scott Keene
Extreme GTAC
