Avaya ERS - wired captive portal with Extreme Access
portier
Does anyone know if it is possible to configure wired captive portal on avaya ERS switches with Extreme Access?
So far, I've found zilch about this setup and I want to know if it is possible to do this kind of setup?
If it is possible, does anyone have any configuration examples/guides/.... to get me started?
Kind regards,
P
1 ACCEPTED SOLUTION
EXTR_Paul
ERS switches do not support this.
however, this question should get asked in the XMC/CONTROL thread.
2 REPLIES 2
Tomasz
Valued Contributor II
What is your approach reason. Is it necessary to do redirection on the access switch?
You might want to use couple of methods for wired Captive Portal redirection, like DNS Proxy or PBR (on a gateway router).
Please provide us with couple of more details.
Kind regards,
Tomasz
EXTR_Paul
