Backup wireless controller configuration with inventory manager
Husam
New Contributor II
I am trying to configure an archive in inventory manager to backup the wireless controller. I did all below but it is not working:
1- configured the SCP options in inventory manager with the netsight account
2- configured the image information in inventory manager for wireless controller as below
  • firmware MIB : script
  • configuration MIB : script.
  • device family definition: entrasys wireless controller -SCP
The error message is (Configuration Upload script is empty in file Enterasys Networks Wireless Controller - SCP)
note: I tried to use "controlled by device type" for configuration MIB, but also it did not work and the error message is (Device Reported - There is no such file or directory)
Anyone have an appreciated advice?
PS. I can access the wireless controller well from netsight and I can execute commands over SSH.
Thanks
Husam
1454b3716e714392ade0a0ac70ac1101_RackMultipart20151230-10751-l5462n-Capture1_inline.jpg
11 REPLIES 11
Husam
New Contributor II
Thank you for your response.
I think that it needs special script as the enrerasys is consider a third party in this case but even scripting have not worked.
Do you have any advice according to creating script or if there should be a built-in script?
Thanks in advance,
Husam
davidj_cogliane
Contributor
I am not very familiar with the WiFi products, but thought since they came from Enterisis they would work off mibs and snmp. I thought the scripting was primarily for my Extreme xos switches. Just my thoughts on the matter, I'm taking the wireless class on the 19th
