BD-8810 10 g up-links not showing Raw data
Mohammed_Jashee
New Contributor III
Hi
Am facing BD-8810 10 g up-links not showing Raw data OneView.
f8632b53afd04556b73b15c81f40cd7f_RackMultipart20160208-96933-16a1d11-bd-8810_inline.png
5 REPLIES 5
Drew_C
Valued Contributor III
Hi Mohammed, were you able to get this issue resolved?
Mohammed_Jashee
New Contributor III
I can see the raw report in custom report .
Frank_Thomas
I see
If you go to custom reports. Can you view the raw data for the port?
f96b1ceb38e5409ba9228a316698b379_RackMultipart20160211-89879-1xw4l1w-inoutoctets_inline.png
Mohammed_Jashee
New Contributor III
Hi Thomas,
Yes am enabled historical collection on the port. Its showing Hourly & Daily Data.Raw Data only not showing.
