stack grayed out in inventory manager using firmware manangement
JohanHendrikx
Contributor II
I want to do a firmware upgrade using inventory management. The stack is gray out. An other stack I can do an upgrade. Both stacks are simular (same modules and same firmware.)
Why is the stack gray out ?
Johan Hendrik System Architect Audax
7 REPLIES 7
Paul_Poyant
New Contributor III
This is probably an SNMP Polling thing.
See "Netsight: All devices grayed out in the firmware upgrade wizard" in GTAC Knowledge.
I believe a key point of that article is that SNMP Polling is device-specific - so that it could be enabled on one device and disabled on a different (and grayed out) device.
Paul, not all my devices are grayed out.
Zdeněk_Pala
Sometimes it helps to rediscover the switch = netsight console -> choose the device -> rightclick -> refresh (rediscover) From my understanding the swith was not reachable during the discovery and the device type is not fully propagated through the Netsight. Good luck
Regards Zdeněk Pala
