Bug : Netsight -> Device View -> Device Logs Repolling -> Filtering Not Honored
‎10-03-2018 01:41 PM
Hi Guys,
I've been having an issue viewing the Trap Logs and Syslogs for a particular device.
If I click on Network -> Devices -> Click gray Arrow Next to a Switch to enter Device View -> Click on Device Logs.
The Syslog and Trap events are initially automatically filtered by the device I clicked on but after a syslog or trap repoll ( i believe is set to 60 seconds) that default filter is erased and I see syslog and traps for every device.
If i then manually enter a filter by source, it filters on that , but then again on the 60 second repoll gets ignored.
The same issue occurs in Alarms and Events -> Events -> Syslog.
If you enter in a filter on a column, the filter isn't honored on the next repoll
This makes viewing the syslogs or traps through Netsight more complicated and frustrating.
Can someone take a look at this?
Verified on version: 8.1.3.65
11 REPLIES 11
‎10-04-2018 01:27 PM
I assume Pala meant the latest version - I'm running v8.1.4.40 and my Alarms&Events filtering works.
....device logs is in the state you've mentioned.
‎10-04-2018 09:46 AM
Hi Byron.
Bugs should be reported to GTAC. https://support.extremenetworks.com
the issues with Alarms and Events -> Events should be already fixed.
Regards
Zdeněk Pala
